Hello, While building a project this message appears:
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?CO?AMPL_DRIVER
I know that this warning indicates that there is a part of code in the ampl_driver file that is excluded from the overlay process.
after searching (by commenting code parts) I found out that the warning is caused from a constant 'ref_int_tmpr', which is declared at the 'ampl_driver' file and is used only once in the same file and nowhere else in the project. The constant is used by a function which is included only if defined earlier:
// global declaration: const float code ref_int_tmpr = 40; ... #ifdef __LT out_sig[i] = (out_sig[i] / get_RAM_gain_factor(ampl_param.working_gain)) - low_temperature_correction(case_temperature,t_index,i); #else if(!sensor_mode.delta) { //signal with temperature correction out_sig[i] = (out_sig[i] / get_RAM_gain_factor(ampl_param.working_gain)) * ((1 + ref_int_tmpr * ID1_xram.alpha[i]) / (1 + get_temp_sensor() * ID1_xram.alpha[i])); }//if(!sensor_mode.delta else { //no temperature correction out_sig[i] = out_sig[i] / get_RAM_gain_factor(ampl_param.working_gain); } #endif //__LT
When the _LT option is defined (the #else part isn't executed) the error appears. The problem is that the warning stays also after commenting/ entering into the define choice the declaration part:
#ifndef __LT const float code ref_int_tmpr = 40 #endif
Any idea why? Thanks, Amitai
maybe the compiler is inlining the value? after all, it is a constant. could be a define anyway and then that store in a code segment wouldn't be required.
Take a look to the MAP file and identify the size of the segment. I believe you might have more than just this variable.
You may then use the compiler listing (using the SYMBOLS option) to identify which other symbols are allocated to that segment.
