Hi
Can we use internal regulator for ref voltage of ADC of STM32L152? if you have experienced it please tel me how to do?
I am using
ADC_TempSensorVrefintCmd(ENABLE);
but it works with external vref my code is:
void ADC_Init(void) { ADC_InitTypeDef ADC_InitStructure; /* Enable ADC clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE); /* de-initialize ADC */ ADC_DeInit(ADC1); /* ADC configured as follow: - NbrOfChannel = 1 - ADC_Channel_9 - Mode = Single ConversionMode(ContinuousConvMode disabled) - Resolution = 12Bits - Prescaler = /1 - sampling time 192 */ /* ADC Configuration */ ADC_StructInit(&ADC_InitStructure); ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b; ADC_InitStructure.ADC_ScanConvMode = ENABLE; ADC_InitStructure.ADC_ContinuousConvMode = DISABLE; ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None; ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfConversion = 1; ADC_Init(ADC1, &ADC_InitStructure); /* ADC1 regular channel9 configuration */ ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 1, ADC_SampleTime_192Cycles); ADC_DelaySelectionConfig(ADC1, ADC_DelayLength_Freeze); ADC_PowerDownCmd(ADC1, ADC_PowerDown_Idle_Delay, ENABLE); /* Enable ADC1 */ ADC_Cmd(ADC1, ENABLE); /* Wait until ADC1 ON status */ while (ADC_GetFlagStatus(ADC1, ADC_FLAG_ADONS) == RESET) { } }
uint16_t ADC_Supply(void) { uint8_t i; uint16_t res; /* Initializes ADC */ ADC_Init(); ADC_TempSensorVrefintCmd(ENABLE); /* ADC1 regular channel 9 for VREF configuration */ ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 1, ADC_SampleTime_192Cycles); /* initialize result */ res = 0; for(i=4; i>0; i--) { /* start ADC convertion by software */ ADC_SoftwareStartConv(ADC1); /* wait until end-of-covertion */ while( ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC) == 0 ); /* read ADC convertion result */ res += ADC_GetConversionValue(ADC1); } /* de-initialize ADC */ ADC_TempSensorVrefintCmd(DISABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, DISABLE); return (res>>2); }
What values are you reading, and what do you expect to see?
I'm not sure the ADC *uses* it as a reference as much as it allows you to determine the value of your supplied +VREF
Thanks for reply. I read by this command:
battery_val=ADC_Supply();
which calls
I have not connected VREF+ to any power source in my board is there a way to connect it internally to vref of MCU by software?
Which part exactly are you using? Some devices have +VREF internally bonded to VDDA, and -VREF internally bonded to VSSA. On devices with VREF pins *you* have to connect them to the supplies yourself, in your design. I'm reasonably sure there is not a magic software setting, but try reading the manuals.
Isn't VREFINT on CHANNEL 17?
www.st.com/.../CD00277537.pdf
