RL-ARM TCPNET with RTX not working
hi
i am implementing tcpnet tcp/ip stack with rtx and i have read the keil instructions. but this code doesnt work and no tcp packet is sent to the pc. i am confused and dont know what to do to eliminate the fault.
here is my code
init task :
__task void tcp_init1 (void)
{ init ();
init_TcpNet ();
debug_frmwrk_init();
tcp_tick_tsk=os_tsk_create (tcp_tick, 3);
 tcp_main_tsk=os_tsk_create (tcp_main, 1);
tcp_send_rec_tsk=os_tsk_create (tcp_send_rec,2);
 os_mut_init(mutex_TcpNet); /* Init done, terminate this task. */
os_tsk_delete_self ();
task 1 :
__task void tcp_tick (void)
{ os_itv_set (100);
 while (1) {
os_itv_wait (); /* Timer tick every 100 ms */
 timer_tick ();
 os_evt_set(0x0001, tcp_main_tsk); }
task 2 :
__task void tcp_main (void)
while (1)
 os_mut_wait (mutex_TcpNet, 0xffff);
 os_evt_wait_and(0x0001, 0xFFFF);
main_TcpNet ();
os_mut_release (mutex_TcpNet);
 os_tsk_pass (); }
task 3 :
__task void tcp_send_rec (void)
{ uint8_t *sendbuf;
 U16 k;
tcp_soc = tcp_get_socket (TCP_TYPE_CLIENT_SERVER | TCP_TYPE_KEEP_ALIVE, 0,30,tcp_callback);
tcp_listen (tcp_soc, 1001);
 for(;;) {
switch (tcp_get_state (tcp_soc))
    case TCP_STATE_FREE:
    case TCP_STATE_CLOSED:
   case TCP_STATE_LISTEN:
    tcp_connect (tcp_soc, Rem_IP, 1001, 0);
   break;
   case TCP_STATE_CONNECT:
   if (tcp_check_send (tcp_soc) == __TRUE) {
       sendbuf = tcp_get_buf(10);
       //Fill buffer in here
      for(k=0;k<10;k++) sendbuf[k] = 0x41 + k%10;
      tcp_send (tcp_soc, sendbuf, 10);
      break;
} os_mut_release (mutex_TcpNet);
  • i have edited my code and some of problems seems to be solved but still not any paket isnt sent to the pc. my edited code is as below. i transfered the initializing functions from tasks to the starting lines of main function.
    init task :
    task 1 :
    { os_itv_set (100);
     while (1) {
     timer_tick ();
    task 2 :
    while (1)
    main_TcpNet ();
     os_tsk_pass (); }
    task 3 :
    { uint8_t *sendbuf;
     U16 k;
     for(;;) {
       break;
          break;
    main func.
    void main (void) {
       init ();
       init_TcpNet ();
       tcp_soc = tcp_get_socket (TCP_TYPE_CLIENT_SERVER | TCP_TYPE_KEEP_ALIVE, 0, 30,tcp_callback);
       os_sys_init (tcp_init1);
            while(1)
