hii... i am using STMM32L053 chip in keil uvision 5 and i am new to it.
Can i run a simple program for data transmission (USART).. using a simulator...? i configured the pins and USART using STM32Cubemx software. will this code work..->
/* HAL_UART_Transmit((UART_HandleTypeDef *)&huart2, (uint8_t *)"k", 1, 5000); */
they provide the option for using simulator under options->debug i selected those..but received a problem..->
*** error 65: access violation at 0x40021000 : no 'read' permission
i assigned the memory map...and the program is running.. but still there ain't a output..!!
Please provide a solution for this...
also refer to "Simulation of Cortex-M Devices with MDK-5": http://www.keil.com/support/docs/3726.htm
