My SD card detect pin, is not connected so How can I omit USBD_MSC0_CheckMedia() function? I rewrited that function but PC did't detect it.
uint32_t USBD_MSC0_CheckMedia (void) { #if (USE_FILE_SYSTEM == 1) // If File System is used uint32_t param_status; uint8_t media_state; // Bit 0. media ready, Bit 1. media write protect static uint8_t media_ready_ex = 0U; // Previous media ready state uint8_t own; Get current media status media_state = 0U; media_state = USBD_MSC_MEDIA_READY; media_state |= USBD_MSC_MEDIA_PROTECTED; return media_state; #else return USBD_MSC_MEDIA_READY; #endif }
Please guid me,I rewrite this function again and again but PC didn't detect SD card. (PC Detected USB Device but in Removable Disk case)
At first,I commented this function but PC detected USB device as "Removable Disk" then I rewrite it in some states but the problem remained. I really don't know what's wrong! what's the reason of this problem? check_media function or another thing?(I checked necessary jumpers and my microcontroller is LPC1768)
But don't you think a USB memory is removable?
Shouldn't Windows or whatever OS you use give you a choice of "Safely remove" a USB-connected memory?
Sorry Per,I don't understand what you mean.I can eject it safely,but my problem is that PC don't detect USB device is the SD card connected to the board!(and just detects it as Removable Disk) or PC don't allow me to access SD card.
