Does the ST-Link debug adapter support logging of trace data? I'm using a Nucleo board and according to the schematic the SWO pin on the target MCU is connected to the debug adapter, but there is no Trace Data menu item under View/Trace.
In the documentation only the ULink adapter is mentioned to be used with trace data. I did not find any information whether this feature is supported by other adapters or not. A feature matrix could be really helpful I think.
I think I have seen trace data with other adapters earlier. Like Freescales's Freadom board or NXP's LPCXpresso, but I have to check.
In case of the ST-Link adapter there is no option for SWJ in the settings window of the adapter. Might it be the problem? May I assume that only those adapters support this feature which has SWJ option?
Thanks and regards, Laszlo
ST-Link also supports Trace. However you need to use the SWD communication mode as trace is output via SWO.
Take a look here:
- http://www.keil.com/appnotes/files/apnt_268.pdf - page 23 - http://www.keil.com/appnotes/files/apnt_253.pdf - page 4
Not every board supports that and on some you need to solder a bridge.
SWV/SWO interface works fine on ST-LINK and Nucleo devices. Not going to work on Cortex-M0 parts.
The frequency settings in the Trace pane needs to match the speed you're running the processor.
Hi Westonsupermare Pier,
Thanks for your quick and kind reply. I have a CM4F device so I think it should work.
Thanks for the hint regarding the operating frequency, I have double checked and it was not correctly set.
As I have written in my previous reply, now the Trace feature seems to work, but I can not activate the Instruction Trace Window for some reason.
Thanks for your kind help.
Best regards, Laszlo
