LPC 3250 UART Tx IRQ (Interrupt Related)
I'm using LPC 3250 Developer's Kit. I want to study the UART 5 with the TX interrupt enabled. Here is the piece of c code compiled using RVDS and debugged using DSTREAM.
The program is transmitting the characters to hyper terminal but I was expecting the character 'I' to be transmitted when it enters the IRQ ISR. But it didn't.
Need your assistance to generate interrupt in IRQ mode for UART 5 Transmission.
Thank You
S GR
#include "lpc32xx_uart.h"
#include "lpc32xx_timer.h"
#include "lpc32xx_chip.h"
*Function    :send_data
*Inputs      :string
*Output      :none
*Purpose         :To print the string on serial port
void send_data(unsigned char ch)
         UartReg.dll_fifo=ch;
         while(!(UartReg.lsr  & 0x20));
*Inputs      :string
*Output      :none
void send_string(volatile unsigned char *str)
        while(*str != '\0')
                send_data(*str);
                str++;
*Function    :receive_data
*Inputs      :string
*Output      :none
 unsigned char receive_data(void)
        unsigned char ch;
        while(!(UartReg.lsr & 0x01));
         ch=UartReg.dll_fifo;
         return(ch);
*Function    :uart5_MICInit
*Inputs      :
*Output      :
*Purpose         :
void uart5_MICInit(void)
        UartReg.dlm_ier = UART_IER_THRE; // Enable UART Tx Interrupt
        MIC_APR |=  (1<<9);     // Activation Polarity (Active High for UART 5)
        MIC_ATR &= ~(1<<9);     // Activation Type (Level 0)
        MIC_ITR &= ~(1<<9);   // Interrupt Type (IRQ = 0)
        MIC_ER  |=  (1<<9);     // Enable register for UART 5
int main(void)
        uart5_MICInit();
        send_string((unsigned char *)"UART5 LPC3250 \n\r");
        while(1)
                ch = receive_data();
                send_data(ch);
        return 1;
__irq void IRQ_Handler(void)
    send_data('I'); // for uart5
    return;
