im using lpc1768 i connected button to P0.5, led to P0.4 initially the button pin should go low, if i press the button P0.5 should get high but the pin is always high i checked the pin with multimeter without connecting button it is giving 3.3v here is my code
#include "lpc17xx.h" #define led (1<<4); #define button (1<<5) uint32_t buttonstate; int main(void) { SystemInit(); LPC_GPIO0->FIODIR |= led; //output LPC_GPIO0->FIODIR &= ~(button); // input LPC_PINCON->PINSEL0 &=~((1<<9)|(1<<8)); //led pin gpio function LPC_PINCON->PINSEL0 &=~((1<<11)|(1<<10)); //button pin gpio function LPC_PINCON->PINMODE0 |= ((1<<11)|(1<<10)); //button pin pulldown mode function while(1) { buttonstate = ((LPC_GPIO0->FIOPIN & button)>> 5); if(buttonstate) { LPC_GPIO0->FIOSET |= led; } else { LPC_GPIO0->FIOCLR |=led; } } }
Sounds strange - the weak pull-up would normally manage to make all pins reach 3V3 unless external hardware loads the pins.
In your case, it sounds like the other pins are floating. But the default value of the PINMODE registers should be that the pins should have weak pull-up enabled.
All other pins in the port giving 2.36v but P0.5 and P0.4 is giving 3.3v. how to make P0.5 low initially i mean in the software so that when i press my button the pin becomes high
How do you know the program starts? In reset the inputs are always high. And this is a reason for using high as idle - so having button short to ground or light LED or draw relay by setting output pins low.
