I am using my own board aduc7026. I wrote the program for dac, it is working fine, same program written in timer interrupt using timer1 but this is not working. i am using the compiler uvision 5.05.Please send any change in start up file and or send example program for that.
Did you install the Legacy Pack for MDK v5.15? If so, you should have an example project in the folder .\ARM\Boards\ADI\ADuC702X\Dimmer. This example uses a timer interrupt.
