Hi I am trying to use EXTI interrupt which should toggle an led but program stops in an endless loop when I use the following code. I am using STM32L1 discovery board. I had the same problem when using TIM2 interrupt too. a part of my code is:
EXTI_InitTypeDef EXTI_InitStructure; void EXTILine0_Config(void); void ExtInt(void) { /* Configure EXTI Line0 (connected to PA0 pin) in interrupt mode */ EXTILine0_Config(); /* Generate software interrupt: simulate a rising edge applied on EXTI0 line */ EXTI_GenerateSWInterrupt(EXTI_Line0); } void EXTILine0_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; /* Enable GPIOA clock */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE); /* Enable SYSCFG clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE); /* Configure PA0 pin as input floating */ GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; GPIO_Init(GPIOA, &GPIO_InitStructure); /* Connect EXTI Line0 to PA0 pin */ SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOA, EXTI_PinSource0); /* Configure EXTI Line0 */ EXTI_InitStructure.EXTI_Line = EXTI_Line0; EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising; EXTI_InitStructure.EXTI_LineCmd = ENABLE; EXTI_Init(&EXTI_InitStructure); /* Enable and set EXTI Line0 Interrupt to the lowest priority */ NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x01; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x01; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } /** * @brief This function handles External line 0 interrupt request. * @param None * @retval None */ void EXTI0_IRQHandler(void) { if(EXTI_GetITStatus(EXTI_Line0) != RESET) { /* Toggle LED1 */ GPIO_ToggleBits(GPIOB, LED_Blue); /* Clear the EXTI line 0 pending bit */ EXTI_ClearITPendingBit(EXTI_Line0); } } main(){ ExtInt(); while(1) { GPIO_ToggleBits(GPIOB,LED_Green);//GPIO_ToggleBits(GPIOB,LED_Blue); for(i=0;i<200000;i++){ }; } }
Where, exactly, is that "endless loop".
Is it the Hard Fault handler ... ?
The problem solved after I removed the file below which I had written it for timer interrupt
void Init_NVIC(void) { NVIC_InitTypeDef NVIC_InitStructure; //NVIC_SETPRIMASK(); // NVIC init #ifndef EMB_FLASH /* Set the Vector Table base location at 0x20000000 */ NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0); #else /* VECT_TAB_FLASH */ /* Set the Vector Table base location at 0x08000000 */ NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0); #endif NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4); NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 7; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); NVIC_EnableIRQ(TIM2_IRQn); TIM2->DIER = TIM_DIER_UIE; }
I modified it like below:
NVIC_InitTypeDef NVIC_InitStructure; NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x01; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x01; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); // Clear update interrupt bit TIM_ClearITPendingBit(TIM2, TIM_IT_Update); // Enable update interrupt TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
