Dear experts,
I resetup Keil programme on my computer and try to build one of my old projects which worked well. But now I am not able to rebuild this project again since the error shows up at everytime compiling c file.
It says that : The Operation of ARM C/C++ Compiler has been stopped.(Translated. I dont know the words exactly in English)
The details - Name: BEX application program name: ArmCC.exe application program version: 5.5.0.106 program stamp: 547650a9 error module name: ArmCC.exe -- goon --
I tried to change other old and latest versions, I have no idea what this error means and how to solve. Please help. Thank you.
That sounds like a problem of the compiler in combination with your source code. Can you please send the source code (or the project) that creates the crash to support.intl@keil.com so that we replicate this problem and fix it in the next version.
As work-around I suggest that you select the old compiler as explained here: http://www.keil.com/support/man/docs/uv4/uv4_armcompilers.htm
MDK v5.12 and higher include both the v5.04u2 and the V5.05 compiler. The compiler version can be easily selected in Project - Options for Target - Target
