I am working on a STM32F407 discovery board. One of the needs of my application is to keep close track of the register contents. Hence i wish to be able to dump these contents into a file for verification purposes. I also wish to be able to dump the entire memory space .
I have been able to use the LOG debug command to dump the contents of my registers as follows : LOG > a.dumplog d r1 d main ... LOG OFF
Is it possible to configure the display results from say ; d r1 0x00000000 E8 12 00 20 B9 03 00 08 - C1 03 00 08 C3 03 00 08 ... ............ 0x00000010 C5 03 00 08 C7 03 00 08 - C9 03 00 08 00 00 00 00 ................ 0x00000020 00 00 00 00 00 00 00 00 - 00 00 00 00 A1 02 00 08 ................ 0x00000030 CD 03 00 08 00 00 00 00 - 41 03 00 08 A5 03 00 08 ........A....... 0x00000040 D3 03 00 08 D3 03 00 08 - D3 03 00 08 D3 03 00 08 ................ 0x00000050 D3 03 00 08 D3 03 00 08 - D3 03 00 08 D3 03 00 08 ................ 0x00000060 D3 03 00 08 D3 03 00 08 - D3 03 00 08 D3 03 00 08 ................ 0x00000070 D3 03 00 08 D3 03 00 08 - D3 03 00 08 D3 03 00 08 ................ to a shorter cleaner d r1 0x00000000 E8 12 00 20 B9 03 00 08 - C1 03 00 08 C3 03 00 08 ... ............ Also how to address the entire RAM address space and dump it as well ? And finally how do i format my log file so that it is not one big dump file but i can write some print statements to prettify the output to read easily .
Note that not all registers are safe to save - some may have read-only properties that makes a read result in clear of internal processor state. So you might acknowledge the reception of a UART character, or acknowledge a pending interrupt.
http://www.keil.com/support/man/docs/uv4/uv4_cm_save.htm
