I am fairly new to Keil MDK-ARM, just evaluating it the last week.
I was guided to MDK v5 by a rep but was rather upset when I found that CANbus is not available in MDK-ARM v5 until Q3 2015. Per this article http://www.keil.com/support/docs/3694.htm
I have the MCBSTM32F400 eval kit which has the STM32F407. My application requires a TCP server, LCD & 2 CAN bus ports.
I was able to get the CAN demo from MDK v4 running on my MCBSTM32F400.
I got an MDK v5 app running with a TCP server & Http server & LCD display code. I would like to add CANbus to this app.
So my question, is there a way for me to merge these two apps in MDK v5? ---I spent a couple hours digging around in the source and it looks like the MDK RTOS is just to different between MDK v4 & v5 to make this work. Or I just cant find a way to do it.
OR to get everything I need would I have to Refactor my TCPIP\LCD app into mDK v4 to add CANbus into the MDK v4 project?
Thanks in advance,
There is an example available that shows how to port RL-CAN to MDK Version 5 and CMSIS-RTOS. www.keil.com/.../3714.htm
Thank you so much,
That was one helpful appnote!
issue closed
http://www.keil.com/support/3714.htm is the KB article link
