User-defined function in uVision5
Hi everyone,
I have an assembly code that I want to run in uVision4.
The .a51 code is as follows:
        MOV A, #002H
        MOV     R0,  #040H
        MOV 040H, #001H
        XCH     A, @R0
        MOV     R0,  #050H
        MOV     050H, #0F0H
        XCH     A, @R0
        MOV     R1,  #060H
        MOV     060H, #0FFH
        MOV     A, #0A0H
        XCH A, @R1
        DB      0A5H
        END
When I run the code using the debugger in uVision4, it works properly and I can either step through the instructions and see the result on the registers and memory addresses, or run the whole program and see the final result. I can also use the uVision4 built-in debug functions to do the same.
The problem arises though, when I want to do the same stepping in my code, using some user-defined functions.
Here are my scripts and functions:
include tb_run_instructions.ini
include test_instr_xch_a_at_ri.ini
Func void test_instr(void)
        test_instr_xch_a_at_ri();
        return;
Func void test_instr_xch_a_at_ri(void)
        exec ("T 4");
        tb_run_instructions(4);
        exec ("T 3");
        tb_run_instructions(3);
        exec ("T 4");
        return;
Func void tb_run_instructions(int inst)
        printf("%d instructions were executed\n", inst);
        return;
I run my code as:
In the command line of uVision I first include the main function, which includes the other required functions
include test_instr.ini
Then I run this function, which in turns run the other functions using
test_instr()
The problem is that only the first exec line in my function runs and the second and third execs shown in test_instr_xch_a_at_ri, do not run.
Interestingly all the tb_run_instructions functions run and print their messages.
The final output in the command window of uVision4 is:
4 instructions were executed
3 instructions were executed
But only the first four instructions were executed, and nothing happened afterwards.
Can you please help me to find out, where the problem is and how I can fix this, to run all required exec ("T x") in my script?
Cheers,
Mostafa
