I tried to configure timer for sec. But unable to get it working for 1 sec. Instead is somewhere between 2 and 3 sec. Below is the code. Do anyone see something wrong with the code? Note: Crystal - 12 MHz. CCLK = 60 MHz (I verified this by reading PLL0STAT and it is 0x00000724). Also VPBDIV=0x00000000 after reading it, meaning PCLK = 15 MHz.
// Function to give 1 msec delay void delayMS(unsigned int milliseconds) //Using Timer0 { T0TCR = 0x02; //Reset Timer T0TCR = 0x01; //Enable timer while(T0TC < milliseconds); //wait until timer counter reaches the desired delay T0TCR = 0x00; //Disable timer } // Initialize the Timer resolution for 1 msec with PCLK = 15 MHz. void initTimer0For1msec(void) { /*PLL0 has been setup with CCLK = 60Mhz and PCLK = 15Mhz.*/ T0CTCR = 0x0; // Select the timer mode. By default timer mode is selected. Not required to do again. // But still to be on safer side. T0PR = 60000; // Increment T0TC at every 60000 clock cycles //60000 clock cycles @15Mhz = 1 msec T0TCR = 0x02; //Reset Timer. Both T0PC and T0TC are reset to zero until bit 2 is made 0 again. }
Figured out the problem myself. T0PR was not initialized correctly (Overlooked) in initTimer0For1msec. Correct value for 1 msec resultions at PCLK= 15 Mhz is
T0PR = 15000-1;
Sorry, I did not indicate the controller. It is LPC2148
