Loaded code "disappears" after a power cycle
I am using the MPC2300 with an LPC2368 NXP / Philips processor with uVision 3.
The problem I am having is with file/image size. When loading anything lower than 64KB the program works and runs perfectly fine after doing a full power cycle. The LPC2368 acts as a slave to another processor which runs the OS, etc.
Anything over 64KB it's like the code loaded in isn't even there after the power cycle. After doing a power cycle and the system is booted, issuing a reboot then solves the problem. I am going to assume there is some default size limitations? Is there some modifications I need to make to be able to load files over 64KB onto the LPC2368 such as changing the memory map?
Is it a uVision setting I am missing?
I've tried setting --entry Reset_Handler / main / __main / 0x00000000
I've tried increasing stack and heap size.
Still stuck with this problem. Any ideas on a solution?
Thanks all.
