When i press the run button(debugging) in keilmuvision 4 in simulator mode it is turning out a message stating that "keil mu vision 4 IDE stopped working" and it states that windows looks for possible solution.I had worked on many projects with same settings which worked fine.But i dont understand how the problem has came now.
Can you please tell any softwares(addditional) has to downloaded to use debugging mode in Keil-4
I am using keil MDK version -4
Please help me.
Thanks in advance, k.saideep.
