Struct error
I'm trying to port code written for the CROSSWORKS_ARM_COMPILER to C51 and Keil will not accept the following definition:
        typedef struct _FFS_FILE
        DWORD directory_entry_sector;
        BYTE directory_entry_within_sector;
        DWORD current_cluster;
        BYTE current_sector;
        WORD current_byte;
        DWORD current_byte_within_file;
        DWORD file_size;
        union
                struct
                        unsigned int file_is_open                               :1;
                        unsigned int read_permitted                             :1;
                        unsigned int write_permitted                    :1;
                        unsigned int write_append_only                  :1;
                        unsigned int inc_posn_before_next_rw    :1;
                        unsigned int access_error                               :1;
                        unsigned int end_of_file                                :1;
                        unsigned int file_size_has_changed              :1;
                        unsigned int reserved                                   :8;
                } bits;
                WORD word;
        } flags;
} FFS_FILE;
I get this error:
ffs.h(131): error C141: syntax error near 'DWORD'
ffs.h(131): error C129: missing ';' before 'directory_entry_sector'
I'm not well versed in C and any help will be appreciated. Thanks,
John
