All,
I have a task to acquire a block of ADC samples, process them, and display the rms result. I have successfully setup the processor on a nucleo STM32F401 development board, and can read ADC data plus compute the rms of that dataset.
My trouble occurs when I process the data using arm_biquad_cascade_df1_f32. The rms output is always "1.#INF". I have checked the initialization code, the arrays, etc. The processed data array is >400 samples long and generally becomes +- infinity after a couple hundred data points.
As indicated, the code functions correctly, including performing the same rms function on the sample array. So if I had a 2 V DC signal on the ADC pin, the rms would read approximately 2482 ( [2482/4095] * 3.3V = 2V).
I suspect my problem lies with either the coefficients (I don't believe the polarity on a1 or a2 need to be flipped, but I could be wrong), which were calculated using matlab ellip function,
www.mathworks.com/.../ellip.html
or in my attempt to convert ADC int32 data to float. I have read several forums, which I can list if desired, but I am still not successful. I have 2 arrays; the first is a reference to compare and the second is my original array.
applicable ADC code: float32_t temp_f = 0.0; temp_f = HAL_ADC_GetValue(&hadc1); ADC_samples_ref[BLOCKSIZE] = temp_f; ADC_samples_L[BLOCKSIZE] = ((temp_f-2048)/4095) * S1_Gain; //S1_Gain is the filter gain from matlab
applicable processing code: arm_biquad_casd_df1_inst_f32 S1; float32_t *S1_pState[4*NUMSTAGES]; const float32_t S1_coeffs[5*NUMSTAGES] = {numbers}; // I'm omiting these numbers in this thread arm_biquad_cascade_df1_init_f32(&S1, NUMSTAGES, (float32_t *) &S1_coeffs[0], *S1_pState);
arm_rms_f32(ADC_samples_ref, BLOCKSIZE, &ref_rms); // used only to troubleshoot and validate filters work
arm_biquad_cascade_df1_f32(&S1, (float32_t *) &ADC_samples_L[0], (float32_t *) &low_proc[0], BLOCKSIZE); arm_rms_f32((float32_t *) &low_proc[0], BLOCKSIZE, &low__rms);
I hope this is enough information for assistance; I'm trying to avoid posting large blocks of code. Please let me know if you see a problem, particularly with how I'm creating the floating array, which as I said is where I suspect I have a problem if not the matlab coefficients.
For reference I discovered what the problem was. The software was correct but the coefficients needed to be flipped. I was able to determine this after creating a low pass filter in matlab and importing the coefficients into the board. Creating a tone in matlab using sind() and then importing that table into the chip as well found the results were identical if the polarity of a1 and a2 was flipped.
