I'm using an TI 8051 device with Keil and had a piece of code that is not behaving as I had originally expected. I created a simple piece of testcode to demonstrate this:
char passtest = 0; char tempvar = 0; P0 = 0xAA; tempvar = P0; if(tempvar = 0xAA) { passtest = 1; } else { passtest = 0; }
I would expect that this testcode would end with a passtest value of 1 but this is not the case as, although P0 is set to 0xAA as expected, tempvar has a value of 0xFF. I assume this is because P0 is not a standard variable but is an sfr. I started reading through the 8051 bible and when reading the hardware section, found this:
Special Function Registers ...Read accesses to these addresses will in general return random data, and write accesses will have no effect... (pg 55 www.lpcware.com/.../80C51 Family Hardware Description.pdf)
I searched my code and found the following line in TPIC8300.H file:
sfr P0 = 0x80;
The above statement is providing an address for the P0 register (far as I know) so I assumed the sfr keyword is what makes it either read only or provide unreliable data upon reading (as described in the hardware bible). To test this, I changed the above line to:
char P0 = 0x80;
I found that it is still providing write only access and can't be read back.
My question for this is why? Is P0 a protected variable name used in Keil (in that it can't be configured to be anything but an SFR) or am I trying to change it in the wrong area?
NOTE: I have no intentions of actually changing this in the code, I just want to understand the compiler better (specifically in terms of how Keil handles SFRs and why it would behave differently than I would expect).
