Hi, I want to set access priorities for the AHB bus, But I can not find which register to modify in RefManual, I have found this useful for LCD driver in LPC1788 LCD driver,
The code there is something like this,But unfortunately the addresses seems to changed,So do you know which register should I change?
This code is part of LPC1788 LCD driver
#define MATRIX_ARB (*(volatile U32*)(0x400FC188)) // // Setup BUS priorities // MATRIX_ARB = 0 // Set AHB Matrix priorities [0..3] with 3 being highest priority | (1 << 0) // PRI_ICODE : I-Code bus priority. Should be lower than PRI_DCODE for proper operation. | (2 << 2) // PRI_DCODE : D-Code bus priority. | (0 << 4) // PRI_SYS : System bus priority. | (0 << 6) // PRI_GPDMA : General Purpose DMA controller priority. | (0 << 8) // PRI_ETH : Ethernet: DMA priority. | (3 << 10) // PRI_LCD : LCD DMA priority. | (0 << 12) // PRI_USB : USB DMA priority. ;
