Cant Step through C code
I seem to be having the same issue as someone in this thread:
http://www.keil.com/forum/15652/
I had it before and got it to go away, I'm not sure how...
Now nothing I do works, I cant debug at all...
I can still see the disassembly and step through that, but that isn't that useful when debugging data structures etc.
Does anyone have any clue what could cause this?
It happens when simulating or debugging on chip (STM32F4xx)
I tried deleting all output files and regenerating as well as everything listed in the above thread.
No errors are printed at all.
Any help would be appreciated
  • Did you turn off optimization?
    There is typically not a one-to-one linear representation produced by the compiler, lines can be folded and done in orders that suit the compiler/cpu. You should look at the left column for different shades to see what lines can, and cannot be breakpointed. This is a good indicator if there is specific code behind the line, or not.
    Without seeing the offending code it's hard to know exactly what you're working with or why it might pose difficulty.
