uvision4 nRF5188_xxaa issues
Hi all,
I am completely new to the keil environment. I have programmed arduino boards in the past. I just bought something called AtomWear from kickstarter. It is composed of an nRF51822qfaa MCU.
I have downloaded and installed both the uvision 4 and 5. The AtomWear people suggest using uvision 4 so that is what i'm doing.
When I load I get an error that the device is not found, but up next to the load button I can select it.
When I go to options --> device I cannot find my device there but only a general nRF518xxxx.
I can build successfully (no errors or warnings) but i can't udnerstand how to run this.
I went through the manual of Keil and through the examples but after they build they always run via debug.
When I try to run via debug with my MCU I get an error that there is no J-Link connected (which i'm not really sure how I bypass without buying one - I never used one and all I know is it is used for debugging...)
Can anyone assist or give any insight?
Thanks,
Yoav
