Hello everyone I am trying to connect several LEDs but the tension pins are locked in 1.86 volts. The output is enabled and the pins are configured as output , then write to connect the LEDs to audition without success , I am simulating with proteus . And using a LM3S328 . Can anyone help me please .
#include <stdio.h> #include "../device/lm3s_cmsis.h" #include "../inc/hw_sysctl.h" #include "../driverlib/gpio.h" int main(void) { SYSCTL->RCGC2 |= SYSCTL_SET2_GPIOC; GPIODirModeSet(GPIO_PORTC_BASE, GPIO_PIN_0, GPIO_DIR_MODE_OUT); GPIODirModeSet(GPIO_PORTC_BASE, GPIO_PIN_1, GPIO_DIR_MODE_OUT); GPIODirModeSet(GPIO_PORTC_BASE, GPIO_PIN_2, GPIO_DIR_MODE_OUT); GPIODirModeSet(GPIO_PORTC_BASE, GPIO_PIN_3, GPIO_DIR_MODE_OUT); GPIODirModeSet(GPIO_PORTC_BASE, GPIO_PIN_4, GPIO_DIR_MODE_OUT); GPIODirModeSet(GPIO_PORTC_BASE, GPIO_PIN_5, GPIO_DIR_MODE_OUT); GPIODirModeSet(GPIO_PORTC_BASE, GPIO_PIN_6, GPIO_DIR_MODE_OUT); GPIODirModeSet(GPIO_PORTC_BASE, GPIO_PIN_7, GPIO_DIR_MODE_OUT); while (1) { GPIOPinWrite(GPIO_PORTC_BASE, GPIO_PIN_0, GPIO_PIN_0); GPIOPinWrite(GPIO_PORTC_BASE, GPIO_PIN_1, GPIO_PIN_1); GPIOPinWrite(GPIO_PORTC_BASE, GPIO_PIN_2, GPIO_PIN_2); GPIOPinWrite(GPIO_PORTC_BASE, GPIO_PIN_3, GPIO_PIN_3); GPIOPinWrite(GPIO_PORTC_BASE, GPIO_PIN_4, GPIO_PIN_4); GPIOPinWrite(GPIO_PORTC_BASE, GPIO_PIN_5, GPIO_PIN_5); GPIOPinWrite(GPIO_PORTC_BASE, GPIO_PIN_6, GPIO_PIN_6); GPIOPinWrite(GPIO_PORTC_BASE, GPIO_PIN_7, GPIO_PIN_7); } } <\pre>
