Interfacing with a 4x4 keypad on same bus
Hey, i have a problem that i have been at for over a day now, and i can not solve this with my skills.
So the problem is as follows. I am trying to get an output from a 4x4 keypad, which would not be a problem but input and output are on the same pins. I know that the 74hc573 should keep the information after LE goes low, but i just can not figure out how to read output from 74hc541 without giving new information to the previous chip, because then the state changes again. At the moment i can only read the keys diagonally, because input and output match in that case.
The schematic of the whole circuit can be seen here
:http://i.imgur.com/FWcJRvP.png
and the problematic part here :http://i.imgur.com/i7vwFXs.jpg
Hope you guys can give a tip and help me understand this.
  • Surely, the whole point of a bus is precisely that multiple things do share the same pins?!
    "would not be a problem but input and output are on the same pins"
    Why is that a problem?
    The input pins are only activated during a write operation, then latched, and the output pins are only activated during a read operation.
