I want to use Keil uVision 4 with the ET ARM LPC2119 stamp (by Futurlec). I have managed to write and compile code but the startup.s file is not correct so the program does not run.
Has anyone have the correct startup.s file or the configurations for the LPC2119 in the ET-ARM stamp?
Thanks,
Regards,
Joseph
I have managed to use this board with Keil V5.
Do proper linker settings and should run. Contact me in case you require help about this matter.
Regards, Clive
Futurlec? technical@futurlec.com
Would imagine they're pretty generic modified to address specific components on the board (crystal, pins, etc).
Because errors are always in someone elses code?
How come you're convinced that it's the startup file that's at fault for the program not running, yet you don't know how to fix it?
