Hi friends,
I don't know what is the exact meaning of the expresion (->) in Keil? thanks for any idea.
The same as in bog standard C.
The following code is a part of example for lpc1768 in keil. if you could please describe me this code:
LPC_PINCON->PINSEL1 &= ~(3<<18); /* P0.25 is GPIO
Have you programmed with pointers before? If not, it might be an idea to take a look in some programming book - in this case, the code uses a pointer to a struct.
LPC_PINCON is a pointer to a structure. PINSEL1 is a member of it.
The comment ain't too clever either!
GET A BOOK ON C!
I had not heard about pointer to a structure. Thanks for your advise.
A pointer can point to an int. Or a char. Or a struct. Or a float. Or a function. It doesn't really care - in the general case it can point to anything that can have an address. Note that some architectures have limitations because of non-uniform addressing of the memory.
