Hi, i can't do a software reset on a Keil MCB1800 Board with LPC1857 ARM processor. I use Keil uVision 5 and ULINK-ME as debugger. I have tried many solutions found on Keil and NXP forums without success. Essentially, solution 1 consist on this :
*(volatile unsigned int *)0x40043100 = 0x10400000; //memmap with boot ROM address *(volatile unsigned int *)0x40053100 =(1<<0); // Core reset
and solution 2 is this one :
NVIC_SystemReset();
Also i have disabled all IRQ before to try to reset the board. For solution 1 nothing happen at all after reset instructions, while for solution 2 the program seems to successfuly initiate a reset but stop in the sub-procedure SetClock situated in system_LPC18xx.c and more exactly at this instruction :
LPC_CGU->XTAL_OSC_CTRL = (0 << 0) | /* Enable oscillator-pad */ (0 << 1) | /* Operation with crystal connected */ (0 << 2) ; /* Low-frequency mode */
. If there is no solution to make this board correctly reboot, i want to know if it is possible to produce a reset by connecting a GPIO pin configured as output to the RESET pin of the processor and then setting this pin low until reset occur. I thing this is the best solution (because this will produce real hardware reset effects) but i haven't tried it. Thanks for any response.
