hi ,
I am using keil uvision v4.71 ide. I work on TIVA TM4c129xNczad cortex m4 based microcontroller. Since the board has fatfs file system , i used corresponding fuctions like f_mount , f_open etc to mount the sd card containing the input files to my program and open the file respectively.
Now i want to use the simulator feature present in keil ide. How can i read the input files from my pc ?? Should i use fatfs based file handlers or the normal standard c file handlers? Please give me example so that its clear.
Thanks and regards, Sreenivasa
hi, To add on to my query,
I have doubts like where to place the input file and what functions to use to read the files.
Regards, Sreenivasa
Test generic C code on a PC, or put the files on the SD card and use the real board. I'm not aware of a simple way for the embedded system to have it's files hosted by the PC. The debugger has SAVE, LOAD, LOG, etc.
