Cortex m4 simulator file handlers
hi ,
I am using keil uvision v4.71 ide. I work on TIVA TM4c129xNczad cortex m4 based microcontroller.
Since the board has fatfs file system , i used corresponding fuctions like f_mount , f_open etc to mount the sd card containing the input files to my program and open the file respectively.
Now i want to use the simulator feature present in keil ide. How can i read the input files from my pc ??
Should i use fatfs based file handlers or the normal standard c file handlers?
Please give me example so that its clear.
Thanks and regards,
Sreenivasa
