Hi to all. I'm working on a LPC1788 project. I need to connect MCU to an external NOR flash (S29GL064) and allocate some const variables on it. I wrote a new programming algorithm :
/***********************************************************************/ /* This file is part of the ARM Toolchain package */ /* Copyright KEIL ELEKTRONIK GmbH 2003 - 2011 */ /***********************************************************************/ /* */ /* FlashDev.C: Flash Programming Functions adapted */ /* for Dual M29W640FBx(32-bit Bus) */ /* */ /***********************************************************************/ #include "..\FlashOS.H" // FlashOS Structures #define M8(adr) (*((volatile unsigned char *) (adr))) #define M16(adr) (*((volatile unsigned short *) (adr))) #define M32(adr) (*((volatile unsigned long *) (adr))) #define STACK_SIZE 64 // Stack Size union fsreg { // Flash Status Register struct b { unsigned int q0:1; unsigned int q1:1; unsigned int q2:1; unsigned int q3:1; unsigned int q4:1; unsigned int q5:1; unsigned int q6:1; unsigned int q7:1; } b; unsigned int v; } fsr; unsigned long base_adr; /* * Check if Program/Erase completed * Parameter: adr: Block Start Address * Return Value: 0 - OK, 1 - Failed */ int Polling (unsigned long adr) { unsigned int q6; fsr.v = M16(adr); q6 = fsr.b.q6; do { fsr.v = M16(adr); if (fsr.b.q6 == q6) return (0); // Done q6 = fsr.b.q6; } while (fsr.b.q5 == 0); // Check for Timeout fsr.v = M16(adr); q6 = fsr.b.q6; fsr.v = M16(adr); if (fsr.b.q6 == q6) return (0); // Done M16(adr) = 0xF0; // Reset Device return (1); // Failed } /* * Initialize Flash Programming Functions * Parameter: adr: Device Base Address * clk: Clock Frequency (Hz) * fnc: Function Code (1 - Erase, 2 - Program, 3 - Verify) * Return Value: 0 - OK, 1 - Failed */ int Init (unsigned long adr, unsigned long clk, unsigned long fnc) { base_adr = adr; return (0); } /* * De-Initialize Flash Programming Functions * Parameter: fnc: Function Code (1 - Erase, 2 - Program, 3 - Verify) * Return Value: 0 - OK, 1 - Failed */ int UnInit (unsigned long fnc) { return (0); } /* * Erase complete Flash Memory * Return Value: 0 - OK, 1 - Failed */ int EraseChip (void) { // Start Chip Erase Command M16(base_adr + (0x0555 << 1)) = 0x00AA; M16(base_adr + (0x02AA << 1)) = 0x0055; M16(base_adr + (0x0555 << 1)) = 0x0080; M16(base_adr + (0x0555 << 1)) = 0x00AA; M16(base_adr + (0x02AA << 1)) = 0x0055; M16(base_adr + (0x0555 << 1)) = 0x0010; return (Polling(base_adr)); // Wait until Erase completed } /* * Erase Sector in Flash Memory * Parameter: adr: Sector Address * Return Value: 0 - OK, 1 - Failed */ int EraseSector (unsigned long adr) { // Start Erase Sector Command M16(base_adr + (0x0555 << 1)) = 0x00AA; M16(base_adr + (0x02AA << 1)) = 0x0055; M16(base_adr + (0x0555 << 1)) = 0x0080; M16(base_adr + (0x0555 << 1)) = 0x00AA; M16(base_adr + (0x02AA << 1)) = 0x0055; M16(adr) = 0x30; do { fsr.v = M16(adr); } while (fsr.b.q3 == 0); // Wait for Sector Erase Timeout return (Polling(adr)); // Wait until Erase completed } /* * Program Page in Flash Memory * Parameter: adr: Page Start Address * sz: Page Size * buf: Page Data * Return Value: 0 - OK, 1 - Failed */ int ProgramPage (unsigned long adr, unsigned long sz, unsigned char *buf) { int i; for (i = 0; i < ((sz+3)/4); i++) { // Start Program Command M16(base_adr + (0x555 << 1)) = 0x00AA; M16(base_adr + (0x2AA << 1)) = 0x0055; M16(base_adr + (0x555 << 1)) = 0x00A0; M16(adr) = *((unsigned short *) buf); if (Polling(adr)) return (1); // Wait until Programming completed buf += 2; adr += 2; } return (0); // Done }
and :
/***********************************************************************/ /* This file is part of the ARM Toolchain package */ /* Copyright KEIL ELEKTRONIK GmbH 2003 - 2011 */ /***********************************************************************/ /* */ /* FlashDev.C: Device Description for Dual S29GL064N (32-bit Bus) */ /* */ /***********************************************************************/ #include "..\FlashOS.H" // FlashOS Structures struct FlashDevice const FlashDevice = { FLASH_DRV_VERS, // Driver Version, do not modify! "S29GL064 Flash HY-LPC1788 (By hamid reza mehrabian)", // Device Name EXT16BIT, // Device Type 0x90000000, // Device Start Address 0x00800000, // Device Size in Bytes (8MB) 1024, // Programming Page Size 0, // Reserved, must be 0 0xFF, // Initial Content of Erased Memory 150, // Program Page Timeout 150 mSec 4000, // Erase Sector Timeout 4000 mSec // Specify Size and Address of Sectors 0x10000, 0x00000, // Uniform Sector Size 64kB SECTOR_END };
but at programming after erase and programming , verifying shows error. I think that i need to Active EMC unit in the MCU to make a external memory connection. Can i do it (Init EMC) in the "init function" of the programming algorithm code??? Or there is another way???
The programming algorithm is a small program that gets downloaded to RAM. So it's free to play along with the processor hardware as needed to set up the required hardware to interact with the external memory. Go ahead and add initialization code to the Init() function.
Thanks for your answer This means that can i attach external header files to programming algorithm code?? and can i controls I/O pins in algorithm code??
You will need to do whatever is required to bring up the external interface and talk to the memory part. This will include configuring pins, clocks, peripherals, etc.
You basically "own" the processor.
You can do almost anything. The main exception is to avoid making configuration changes that breaks the JTAG interface since then you lose the ability to receive the data to program.
Thank you But why this code not work???
int Init (unsigned long adr, unsigned long clk, unsigned long fnc) { base_adr = adr; PINSEL_ConfigPin(2,1<<21,0); GPIO_SetDir(2, 1<<21, 1); GPIO_SetValue(2,1<<21); return (0); }
There is a LED in the P2.1 pin. All of the needed headers added to project and FLM file created successfully without any error. What is the MCU frequency along running programming algorithm?? Does i need to set PLL and other clock source registers?? Or The MCU programming algorithm set theme at start point??? Is there any way to debug programming algorithm? ( like set breakpoint )
Ok, the flashing process just JTAG's the applet into RAM along with the data, and runs it. The processor will be in whatever the default reset state is.
The best way to test your flash programming algorithm is to write a small bare metal application framework. Test and debug your code there, and then copy the working code into the flashing applet framework.
Assume the processor is reset, has just entered via the ResetHandler, clocks and PLLs are not enabled, external memory and pins have not been initialized.
