Hello
I'm using u-vision5 and my target H/W is TLE9834 I can't understand why my code can't be build
void filter(U16 RPM) { float omega; omega = (float)RPM; }
Yeh. it was OK.
but.. change code as below..
void filter(U16 RPM) { float omega; omega = (float)RPM*0.10472; }
some errors occured.
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE ...
I checked space but there's big enough space remained.
Somebody help me.. please..
1) Did you check the correct memory region for enough space?
2) Does your C51 license have any code-size limitations?
