Hello, I was tryning to use MDK-ARM 5 I find some difficulties in its configuration. This code is basically used to turn on the led that is connected to the pin 12 of the port D on the STM32F407VG. The problem is when I try to bild it, on error is appeared that says :
main.c(20): error: #268: declaration may not appear after executable statement in block GPIO_InitTypeDef GPIO_InitStructure;
#include "stm32f4xx.h" // Device header #include "stm32f4xx_rcc.h" // Keil::Device:StdPeriph Drivers:RCC #include "stm32f4xx_gpio.h" // Keil::Device:StdPeriph Drivers:GPIO void GPIO(void); int main(){ GPIO(); while(1){ GPIO_SetBits(GPIOD, GPIO_Pin_12); } } void GPIO(){ RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE); GPIO_InitTypeDef GPIO_InitStructure; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; GPIO_InitStructure.GPIO_OType = GPIO_OType_OD; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz; GPIO_Init(GPIOD, &GPIO_InitStructure); }
Can you tell me guys what could be the problem with that. Thank you.
You can move the declaration “GPIO_InitTypeDef GPIO_InitStructure;” to the top of GPIO() function or enable “C99 Mode” in C/C++ options.
It's now working.Thank you. It turns out that the keil has a a very hard configuration. Each time I solve a problem a new one comes out.
Those you seem to have encountered so far appear to be from sloppy coding style. Figure how much fun you'd have if your employer made you run your code through Lint or MISRA before you could commit it to the project?
