hi i would like to get an information about storing code size along with code. in lpc3250 (arm 9) there is a macro SIZE_EXT_INFO to store code size. same way, is it possible to store code size in lpc17xx (cortex m3) ? thanks.
hi, thanks for the replies. i am not able locate the address of the size stored. which location is it? thanks.
It'll be wherever you put it.
Suggest you might place it in an unused vector, at the end of the vector table, with a label you can see in the .MAP file, or using a marker/magic number you can find with a search in a hex editor or such.
