I'd like to import an environment variable into the build. In other IDEs I've been able to do it as a command-line parameter - e.g.: -D FROM_ENV=$(ENV_VARIABLE) or something like that.
The idea is to have an environment variable set ENV_VARIABLE=1234 Then in the code I could write: int i = FROM_ENV;
So far I can't find a way to do it in uVision. I've tried a few combinations in the menu PROJECT->OPTIONS FOR TARGET... dialog, on the C++ tab. There's a field of "Preprocessor symbols" and a "Misc Controls" field where it looks like I could maybe put command-line flags. But my experiments there aren't working.
Is this feature supported?
Doesn't seem to be a Key Sequence for that: http://www.keil.com/support/man/docs/uv4/uv4_ut_keysequence.htm
Hi Peter,
the compiler takes the contents of a specific environment variable. Sadly the name changes with compiler versions. Example: ARMCC5_CCOPT
I used this in past as ARMCC41_CCOPT -DSOMEVAR defines SOMEVAR ARMCC41_CCOPT -DULINK="2" defines ULINK having the value 2
To find out how the name is for your compiler see doc or search exe for "CCOPT".
Just to be complete, the assembler takes an environment variable like ARMCC41_ASMOPT, but syntax differs.
hope that helps
Martin
