Hi, I am trying out ARM Cortex M3 Assembly programming,and also succeeded in writing. All the codes i developed in assembly will get simulated but they don't work on Hardware(LPC1768). Kindly suggest me where i am Wrong. The code is as follows.
;Experiment 1 : To calculate the sum of numbers from 10 to 1 and display the result on Port ;;; Directives PRESERVE8 THUMB UNIFIED ; Vector Table Mapped to Address 0 at Reset ; Linker requires __Vectors to be exported AREA RESET, DATA, READONLY EXPORT __Vectors __Vectors DCD 0x20001000 ; stack pointer value when stack is empty DCD Reset_Handler ; reset vector ALIGN ; The program ; Linker requires Reset_Handler AREA MYCODE, CODE, READONLY ENTRY EXPORT Reset_Handler Reset_Handler ;;;;;;;;;;User Code Starts from the next line;;;;;;;;;;;; MOV R0,#00 ; clear the register R0 MOV R1,#10 ;mov the count value to register loop CMP R1,#00 ; check for condition R1==0 BEQ loopexit ; branch if count is zero ADD R0,R1 ; add the number with previous result SUB R1,#1 ; decrement the count B loop ; loop back loopexit MOV R2,R0 ; keep the result in R2 ;Configuring Port 0 [P0.21-P0.28] to display the Result MOV R3,#0x1FE00000 ; Load the value 0x1FE to change the GPIO0 ; direction as output LDR R0,=0x2009C000 ; Load the Addres of FI0DIR Register STR R3,[R0] ; write value 0xFF to FI0DIR Register LDR R0,=0x2009C01C ; Load the Addres of GPIOClr Register STR R3,[R0] ;write value 0x1FE to to clear the GPIO pins LSL R2,#21; LDR R0,=0x2009C018 ; Load the Addres of GPIOSET Register STR R2,[R0] ; Display the result on GPIO0 FINISH B FINISH ; keep looping infinitly END ; end of a program
So in the debugger what exactly is the nature of the failure as you step through the code? Are your peripheral addresses correct? Are clocks enabled? What does "doesn't work" mean?
Thank You for response,
Doesn't work means, the Port pis are not turning ON. kindly suggest any document for Assembly programming in Cortex M3 on keil
So your code doesn't work.
That's a good reason for starting to debug.
One thing - why does your comments not match the assembler instructions? Haven't you spotted that when you spent time debugging?
