Hi everybody, I've started to use the STM32F4 Discovery, now I'm trying to use the ADC as single channel in conitnuous mode without DMA, i doesn't work , is it posible to do it?
#include "stm32f4xx.h" #include "stm32f4xx_rcc.h" #include "stm32f4xx_gpio.h" #include "stm32f4xx_adc.h" //#include "GPIO_STM32F4xx.h" ADC_InitTypeDef ADC_InitStructure; ADC_CommonInitTypeDef ADC_CommonInitStructure; //DMA_InitTypeDef DMA_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; uint16_t ADCLect=0; uint16_t Counter=0; uint16_t Done=0; volatile uint32_t msTicks; /* counts 1ms timeTicks */ FlagStatus Estado; /*---------------------------------------------------------------------------- SysTick_Handler *----------------------------------------------------------------------------*/ void SysTick_Handler(void) { msTicks++; } /*---------------------------------------------------------------------------- delays number of tick Systicks (happens every 1 ms) *----------------------------------------------------------------------------*/ void Delay (uint32_t dlyTicks) { uint32_t curTicks; curTicks = msTicks; while ((msTicks - curTicks) < dlyTicks); } int main() { SystemCoreClockUpdate(); if (SysTick_Config(SystemCoreClock / 1000)) { /* SysTick 1 msec interrupts */ while (1); /* Capture error */ } RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE); /* Configure PA1 in analog mode */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ; GPIO_Init(GPIOA, &GPIO_InitStructure); /* ADC Common configuration *************************************************/ ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent; ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles; ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled; ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2; ADC_CommonInit(&ADC_CommonInitStructure); /* ADC1 regular channel 12 configuration ************************************/ ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b; ADC_InitStructure.ADC_ScanConvMode = DISABLE; ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//ENABLE;//DISABLE; ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None; ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfConversion = 1; ADC_Init(ADC1, &ADC_InitStructure); ADC_EOCOnEachRegularChannelCmd(ADC1,ENABLE); ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_3Cycles); ADC_ContinuousModeCmd(ADC1,ENABLE); // to make sure the CONT is set /* Enable ADC1 **************************************************************/ ADC_Cmd(ADC1, ENABLE); ADC_SoftwareStartConv(ADC1); while (1) { //ADC_SoftwareStartConv(ADC1); Estado = ADC_GetFlagStatus(ADC1,ADC_FLAG_EOC); if(Estado){ Done=1; ADCLect = ADC_GetConversionValue(ADC1); //ADC_ClearFlag(ADC1,ADC_FLAG_EOC); // to clear the flags events. } Delay(100); } return 0; }
when I use the ADC in mode discontinuous using the code below:
ADC_SoftwareStartConv(ADC1); ADCLect = ADC_GetConversionValue(ADC1); ADC_ClearFlag(ADC1,ADC_FLAG_EOC);
it Works well.
I hope somebody can help me
Hi body, I have the same question! I use HAL-Driver. The function HAL_ADC_START_IT(&hadc1); is called and function HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc) is triggered for only one time and it does't work continues also ADC state have an Error after first conversion. How can I Solve this problem? Any Idea? Tnx...
