uvision v5.11.1.0 could not load file .axf, debugger aborted
I'm attempting to get uvision working on a VM of windows 8.1 embedded industrial running on ubuntu 14.04. when I'm trying to start the debugger with a project that has been tested and working on another computer with uVision. When I try to start the debugger, I first get a message that says: "EVALUATION MODE running with code size limit: 32k"
I then click the okay box and this is the next error code and the debugger gives up:
Error: Could not load file 'X:\ARM\Excercise01\Excercise01.axf'. Debugger aborted !
I attempted an older solution for v3 where I replaced the TLM.DLL but it did not change anything.
I'm not too familiar with this program or windows yet so there might be something I'm missing.
