I need a 100% accurate division of any tow 32 bit numbers. So I am using the following code and the (/) operator. However I notice that results are not accurate when the Den (denominator) is shorter that 32 bit. For example (98765432/01234567) gives 120 where as the correct answer is 80. Can anyone tell me why ? Is something in my code incorrect More important, if this is not a bug, how to fix it ?
Incidentally, I cannot use Printf function so I am using a union function to map the long int variables into 4 unsigned char and the Display the char via a serial port. I don't think that process has introduced any errors in the calculations.
Thanks.
Bhal Tulpule
unsigned long int xdata Num,Den,Res; Num = 98765432; Den = 1234567; Res = Num/Den; //Display Res;
why not?
Probably because it's got a large footprint, and he only paid for the eval version? Or hasn't figured out a way to semi-host it?
Then again converting numbers back and forth between bases is pretty pedestrian stuff.
