Error L6915E use_no_semihosting and sys_exit
Hello guys!
I'm having a problem here. I want to use the printf() function in a STM32F3 application to print debug messages to UART1. I've done this before on a M0 and worked like a charm.
The problem on the M4 is this: If I declare
#pragma import (__use_no_semihosting)
to append my own putc function to print the printf() output to a UART I get linker error
L6915E: Library reports error: __use_no_semihosting was requested, but _sys_exit was referenced
I'm using full assert and the std periph lib nothing more...
Any idea to fix that?
Thanks!
  • When retargeting I use this :
    #include <rt_misc.h>
    #pragma import(__use_no_semihosting_swi)
    struct __FILE { int handle; /* Add whatever you need here */ };
    FILE __stdout;
    FILE __stdin;
    int fputc(int ch, FILE *f)
      ITM_SendChar(ch);
      return(ch);
    int fgetc(FILE *f)
      char ch;
      ch = 1;
      return((int)ch);
    int ferror(FILE *f)
      /* Your implementation of ferror */
      return EOF;
    void _ttywrch(int ch)
      ITM_SendChar(ch);
    void _sys_exit(int return_code)
    label:  goto label;  /* endless loop */
    FILE __stdout;
    FILE __stdin;
      ITM_SendChar(ch);
      return(ch);
    int fgetc(FILE *f)
      char ch;
      ch = 1;
      return((int)ch);
    int ferror(FILE *f)
      return EOF;
      ITM_SendChar(ch);
