plz help me to write code for COUNTER to know given frequency& send it for every 1sec through UART in ARM7(LPC2368).
HOW TO USE TIMER AS A COUNTER,HOW TO COUNT FREQUENCY,IN 1SEC HOW CAN IT SEND TO ANOTHER DEVICE THROUGH CAN ANY BODY PLZ GIVE ME A BRIEF OVERVIEW PLZZ...
Didn't your teacher give you some ideas about the workings of timers?
I think NXP thoroughly documents their parts.
If the task is too complicated, start by doing simpler tasks, and breaking the complex ones down.
HI PARA.
WHAT IT YOUR EMAIL. I SEND U LOTS OFCODE
Well, they did document the LPC23xx chips well enough that I managed to implement counting, timing and frequency-measuring with optional prescaling with the timer modules. But I obviously couldn't do it without reading the documentation - but some people seem to think that the documentation is expected to be read by someone else. Or that the code just magically exist and that the documentation is irrelevant - all that is needed is to just locate that magically existing code.
I SEND U LOTS OF CODE and when the OP turns it in make him ask for a certificte in copying instead of whatever certificate he think he will get
I DOUBT THAT QUANTITY WILL BE THE KEY CRITERION BY WHICH THE HOMEWORK IS MARKED...?
who knows, the "go ahead an copy" 'schools' may just grade on that
yes sir,but how to measure 1 sec using internal clk,ok
T2PR=0X00; T2MR0=15000000/*MY CPUCLK IS 15 MHZ*/
CAP0.0 I AM GIVING ANOTHER FREQUENCY WHICH IS NEEDED TO BE COUNT/*TIMER0 I AM USING AS COUNTER*/ T2 WILL GENERATE INTERUPT AT 1SEC BUT AT THAT TIME IS T0TC WILL HAVE FREQUENCY VALUE.
I KNEW HE WASN'T SERIOUS. HE DIDN'T GIVE ME HIS EMAIL ADDRESS.
ERIK. YOU FRET FOR NOTHING AND TAKE SOME THINGS TOO LITERALLY.
Is there an epidemic attack of caps-lock stickiness going right now?
APPARENTLY.
