Hi All,
I am writing a application for Tiva C series MCU where I need to write/read the file to/from SD card.
If I read the directory by using FATFS library by calling fread as below iFResult = f_readdir(&directory, &File_Info);
here all the file information will be stored in File_Info structure. If I see the file name member in structure it is having as "FLOWER~1.JPG" instead of "flowers_Original.jpg".
Does anyone know why it is overwriting the file name and also I need to access the file by using "FLOWER~1.JPG" name only.
Any help is appreciated.
Thanks srini
Keil claims that they support long file names.
Have you checked if a configuration option needs to be enabled to add this support?
Because long file names is part of an extention to the original FAT file system.
But he's not using Keil's filesystem - he's using FatFs
elm-chan.org/.../00index_e.html
"Have you checked if a configuration option needs to be enabled to add this support?"
Yes, it is - Long File Name (LFN) support is discussed here:
elm-chan.org/.../appnote.html
Exactly. My first response assumed it was Keil's file system layer. But since I failed to get a manual hit on that function on Keil's site I realized what library he used. So my second post specified the changes required with that library.
