I am using Keil uvision5 compiler in Window XP. I want to choose Atmel AT91R4008 ARM7 processor.If I goto a new project project -> select device for targer1,no device is shown in the database. When i go to File->device database the AT91R4008 device is shown in the list.How do I select this IC for my project.
Hello Kayathri,
if you want to use ARM7 processors with MDK Version 5, you need to install the Legacy Pack: www2.keil.com/.../legacy There is a download for ARM7, ARM9, and Cortex-R devices. This should fix your problem.
Kind regards,
Christopher
