I am using a MCB1800 development board. For programming the board i need a UNLink Debugger. Can I instead use H-Jtag software to program the board using parallel port to jtag.
Regards Sanket
Signs point to no, current versions don't seem to support RDI or Wiggler type debuggers.
It will work with J-Link, U-Link and a whole list of debuggers, see debugger selection dialog.
Hi Mr.Pier
None of the devices from 18xx support the wiggler type debuggers. Because i checked, it showed support for 17xx series. Also does 43xx controllers support wiggler debuggers. Intead of jtag debuggers can I flash the code to the MCB1800 development board using the flash magic tool.
Depends if stand-alone programming is what you're looking for, or the ability to program and debug (step, breakpoint, etc).
The documentation and materials for H-JTAG should tell you if the LPC1800 is supported or not, and stand-alone programming is outside the purview of the Keil tools, and integration therein.
If you want to do some debugging it's strongly recommended that you look at JTAG/SWD debugging pods. If you are an educational user, perhaps consider a JLINK-EDU type solution which supports multiple platforms and chips.
