After getting the new keil5 MDK, i compiled the code developed in keil4. (the legacy package has to be installed to achieve the reverse-compatibility).
everything seems to be working fine, except two change:
#define MHZ *10000001 #define SYS_FREQ 60 MHZ #if SYS_FREQ == (120 MHZ) #define SDRAM_PERIOD 8.33 // 96MHz #elif SYS_FREQ == (96 MHZ) #define SDRAM_PERIOD 10.4 // 96MHz #elif SYS_FREQ == (72 MHZ) #define SDRAM_PERIOD 13.8 // 72MHz #elif SYS_FREQ == (60 MHZ) #define SDRAM_PERIOD 16.67 // 72MHz #elif SYS_FREQ == (57 MHZ) #define SDRAM_PERIOD 17.4 // 57.6MHz #elif SYS_FREQ == (48 MHZ) #define SDRAM_PERIOD 20.8 // 48MHz #elif SYS_FREQ == (36 MHZ) #define SDRAM_PERIOD 27.8 // 36MHz #elif SYS_FREQ == (24 MHZ) #define SDRAM_PERIOD 41.7 // 24MHz #elif SYS_FREQ == (12 MHZ) #define SDRAM_PERIOD 83.3 // 12MHz #else #error Frequency not defined #endif //The MHZ (in sdram.h) has to be separated by a white space from the number value, // unlike in keil4 where the white space was not necessary. #include <rtl.h> // Marks a red cross adjacent to this line in the FileConfig.h only (which is the new way of keil to highlight the warnings and error) // the error reads : RTL.H File not found with <angled> include; use "quotes" instead
not sure why this error is shown only in the 'file_config.h'. In all the other .c source files, this error is not displayed. also the project is build and i can download and debug the code (though i have not single stepped through whole code, but think that it may not be an issue of much concern)
It surprises me that someone would have or consider having a define of something like 120MHZ.
It surprises me even more with a definition of MHZ like:
Which represents a very strange conversion from MHz to Hz.
I would definitely prefer a #define that made use of a lower-case L instead of the digit one at the end.
An upper-case L might be a much better choice, though ;->
It surprises me that someone would have or consider having a define of something like 120MHZ. this was a file of an example code. so i didnt bother it much. (ignorant me) but realized this during the compilation in keil5. have fixed it.
but the second query still remains unanswered. #include <rtl.h> // Marks a red cross adjacent to this line in the FileConfig.h only (which is the new way of keil to highlight the warnings and error) // the error reads : RTL.H File not found with <angled> include; use "quotes" instead
