Use source:
#include "stm32f10x.h" void USB_HP_CAN1_TX_IRQHandler() { if(CAN1->TSR & CAN_TSR_RQCP0) CAN1->TSR |= CAN_TSR_RQCP0; if(CAN1->TSR & CAN_TSR_RQCP1) CAN1->TSR |= CAN_TSR_RQCP1; if(CAN1->TSR & CAN_TSR_RQCP2) CAN1->TSR |= CAN_TSR_RQCP2; } int main(){ RCC->APB2ENR |= RCC_APB2ENR_IOPAEN; RCC->APB1ENR |= RCC_APB1ENR_CAN1EN; // PA11 - RX floating // PA12 - TX alt push-pull GPIOA->CRH = 0x444B4444; CAN1->MCR = CAN_MCR_INRQ; while((CAN1->MSR & CAN_MSR_INAK) == 0); CAN1->IER = CAN_IER_TMEIE; CAN1->BTR = 0x12d000f; NVIC_SetPriority(USB_HP_CAN1_TX_IRQn, 0); NVIC_EnableIRQ(USB_HP_CAN1_TX_IRQn); CAN1->MCR = CAN_MCR_NART; while((CAN1->MSR & CAN_MSR_INAK) != 0); while(1){ volatile unsigned int u = 1000000; while(u--); CAN1->sTxMailBox[0].TDTR = 4; CAN1->sTxMailBox[0].TDLR = 1; CAN1->sTxMailBox[0].TIR = 1 << 3 | 1 << 2 | 1; CAN1->sTxMailBox[1].TDTR = 4; CAN1->sTxMailBox[1].TDLR = 1; CAN1->sTxMailBox[1].TIR = 2 << 3 | 1 << 2 | 1; CAN1->sTxMailBox[2].TDTR = 4; CAN1->sTxMailBox[2].TDLR = 1; CAN1->sTxMailBox[2].TIR = 3 << 3 | 1 << 2 | 1; } }
When simulation, only messageBox[0] reset TXRQ bit, end set RQCP0, messageBox[1] and messageBox[2] have TXRQ = 1 and RQCP = 0. If we erase code
then interrupt generated and RQCP0 is set, messageBox[0].TIR copied from messageBox[1].TIR, TXRQ1 = 1. It's problem in my bxCan understanding or Simulator bug? Keil version 4.70.
Does Keil represent that CAN is simulated? See "Simulated Features" http://www.keil.com/dd/chip/4231.htm http://www.keil.com/dd/chip/4889.htm
Hello
There is a version in MDK 4.73 that the CAN simulator works: MCBSTM32E found in MDK 4.73 or a bit earlier. It is in the folder C:\Keil\ARM\Boards\Keil\MCBSTM32E\CAN\CAN.uvproj
You can add 4.73 environment to MDK 5.10 by adding the legacy add-on: www2.keil.com/.../legacy
This method is used in the CAN Primer: http://www.keil.com/appnotes/docs/apnt_236.asp For NXP parts: http://www.keil.com/appnotes/docs/apnt_247.asp Both of these primers are for pre-MDK 5.
Bob
