Hello. I am interfacing a 4x3 keypad with my 8-51 microcontroller. But i keep getting an this error:
temp.c(53): error C141: syntax error near '=' temp.c(55): error C141: syntax error near '='
Here's the code: Please help
#include <reg51.h>
sbit R1 = P1^0; sbit R2 = P1^1; sbit R3 = P1^2; sbit R4 = P1^3; sbit C1 = P1^4; sbit C2 = P1^5; sbit C3 = P1^6;
void main (void) { R1=1; R2=0; R3=0; R4=0; if (C1==1) {P0^0 = 1;} if (C2==1) {P0^1 = 1;} if (C3==1) {P0^2 = 1;}
R1=0; R2=1; R3=0; R4=0; if (C1==1) {P0^3 = 1;} if (C2==1) {P0^4 = 1;} if (C3==1) {P0^5 = 1;}
R1=0; R2=0; R3=1; R4=0; if (C1==1) {P0^6 = 1;} if (C2==1) {P0^7 = 1;} if (C3==1) {P2^0 = 1;}
R1=0; R2=0; R3=0; R4=1; if (C1==1) {P2^1 = 1;} if (C2==1) {P2^2 = 1;} if (C3==1) {P2^3 = 1;} }
When posting code PLEASE READ the posting notes so your code has some form. Highlight specific. line numbers
What on earth does
P0^0 = 1;
do, this isn't valid C syntax, and obviously the compile is going to reject it.
Quite a number of people jumps to the conclusion that Keil's extension to map bit variables to bits of the ports must mean that ^ can also be used inside functions to access individual bits.
When that assumption fails them, they don't take two steps back and reevaluates their assumption.
