The icons in my debug toolbar got screwed up some how. The debug toolbar is using the same icons as the the file toolbar.
For example the debug toolbar is showing the "file open" icon for run and the "save all" for step.
Is there a simple way to reset the toolbars to a default?
Thanks Mike
I am using:
IDE-Version: µVision V4.72.9.0 Copyright (C) 2013 ARM Ltd and ARM Germany GmbH. All rights reserved.
Tool Version Numbers: Toolchain: PK166 Prof. Developers Kit Version: 7.53.0.0 Toolchain Path: C:\keil_C166\C166\BIN EC++ Compiler: EC166.Exe V1.09d C Compiler: C166.Exe V7.53.0.0 Assembler: A166.Exe V5.36.0.1 Linker/Locator: L166.Exe V5.25 Librarian: LIB166.Exe V4.29 Hex Converter: OH166.Exe V4.7c CPU DLL: S166.DLL V3.95.0.0 Dialog DLL: D167.DLL V2.53
Try to use the uVision command Window -> Reset View to Defaults.
