I am in the process of writing a boot loader for my current application and I need to share information between the 2 programs. I am using an STM32F103.
For an example if my boot loader will be located at: IROM1: 0x08000000 to 0x08000FFF IRAM1: 0x20000000 to 0x200001FF
and my application is at:
IROM1: 0x08001000 to 0x08019000 IRAM1: 0x20000200 to 0x20004D00
So if I want to share/update/store the boot loader state used by both programs how do I define an area accessible for both application in so both can read/write to the same ROM and RAM memory locations. I am also assuming the NVIC vector is required to be stored at 0x08000000 for the boot loader and 0x08001000 for the application.
I am assuming if I define variables out side the memory location defined above to read/write from ROM or Read/Write from RAM I would get an error since I will be outside the defined memory area, but maybe I am wrong. Or maybe I am completely wrong.
I just don't want to go to far down this path if this wont work. Or maybe there is a better solution.
thanks for any help.
