Hey community,
i am using Keil uvision 5 with the MDK-ARM 5.10 light and a Segger J-Link EDU.
I am using a LPC2919 Board from Olimex.
My problem is, that when i jump in the Debug-Modus, i can set Breakpoints, but the programm never stops at the breakpoints. Also if i jump in the Debug-Modus from step to step, i see the jumps only in the assembler code (Maybe it should be like that? instead in the C-Code).
Also i can't see the values of some variables or see the time how long the programm is running.
My settings are: Debug Options i selected the J-Link -> Settings: Auto selection, Cache Code, Cache Memory. in the utilities tab i choosed again J-Link and in the Settings my LPC2919. In the Output Register i check "debug informations" and the other 2.
in the Linker misc i've added "--debug".
I tried a lot of diffrent Settings, but nothing works. I hope Somebody can help me.
Greeets Manu
